ircwet
Well tryin to finalize the deal on a 92 Typhoon. Well seems that it does not have a converter on it. Being the weekend, I cant find out what laws are in my state reguarding this. This is the last email discussing this issue. Any inputs would be great !!! Thanks again guys for the help.
Your terms seem agreeable to me.
The only thing on your list that might be an issue is the smog test. I removed the catalytic converter several years ago. The car is registered in Ohio as a collector vehicle and as such does not get smog checked. It would pass a smog test on the basis of emissions as the turbo cleans up the exhaust and the engine is running beautifully; however if the visual inspection includes a look for a cat, you would need a high flow cat such as the Bassini or Random Technologies variants (Bassini is cheaper and work great on my Corvette).
Also I will have to do a treasure hunt for the kick panel in my very remote trailer where I house much of the stuff that doesn't fit in my garage...including a project Syclone sans engine.
I presume you are aware that all stock Typhoon transmissions shift firmly (especially the 1-2 shift) and mine does as well. That can be controlled a bit, but if the TY cable is adjusted correctly, the 1-2 shift is obvious. If you are not well into the accelerator the shift is soft. Mine works exactly the way it is supposed to. It has the expensive Red-Line Racing Transmission oil in it for precision shifting and temperature minimization/reliability.
I think I have mentioned that the paint is original and that original did not include a clear coat. The paint is iin great condition. I did have a very minor scratch fixed on the rear fender and have repainted the cladding purely for cosmetic reasons. Typically, the paint responds well to a polish with a cleaner ingredient as any oxidation is removed with such stuff. Most of the time I just use plain water and a sponge to get it looking great. No accidents or accident damage at all. I would rate the paint a 7 out of 10.
The tires have about 10,000 miles on them and are in decent shape. They are stock-sized Firestone SZ-50's that replaced the original Firestone's that lasted 40,000 miles (that is an indicator of how it has been driven).
The front end is still tight and there ought to be no problems on your expected 1000 mile trip. You will have to stay alert as the wide front tires (stock is wide) respond to bumps and the steering is especially quick (and stock of course) and the wheel base short. You will love the turning radius, but that makes you be alert more than most cars. All that is normal new Ty behavior.
