no injector pulse or check engine light
Captain Morgan
Moderated User
Hey, im relaying this question for a non-internet Typhoon owner.
He is working on a truck that obviously does not run and he cannot get an injector pulse signal and said the check engine light and such does not come on either. He has checked all the grounds and has the Syclone service manual. He had 2 other ECMs laying around but didnt know if they were even good and nothing changed when he installed them so there is a chance they werent. He has also tried another prom, no luck.
Anyone got any clues on what else could be causing this? Im going to probably give him a known good ECM to try and see if that changes things.
Thanks in advance, any thoughts appreciated.
lSyclonel
the only thing i can think of. is a bent pin or broken wire. i think if i remember rite, the injector triger is ground. so see if they have power to them.
May sound stupid, but did he check for a blown fuse?? Get him to check if he has power on on side of the injector wire with the key on. If he doesnt trace the wire to the power sorce. Get him to see if he is getting a gound trigger while crank on the other wire of the injectors, if not trace the wires back to the ecm. This will eliminate shorted/broken wire from injects to ecm. Let me know. Fern Sy#477
Thrillhouse
My blazer just did this about a week before I sold it. Wouldn't start, no injector trigger. Turned out a plug had gone bad, I think it was the one from the ECU to the distributor, anyway it looked like this:
