No Lamda signal
smeagol
The ECM will go into closed loop fueling mode after a coolant threshold is surpassed, as well as a few other thresholds (run time, first 02 transition). Coolant temperature is the main one.
I believe this is what you are asking.
The feedback is based upon short term fueling adjustments made according to readings taken from the oxygen sensor; commanded air-fuel ratio is 14.7:1 during closed loop.
helfmann
Thanks Brian for the answer.
Rolands problem is, that the O2 stays at constant .447mV regardless temp. and engine operation time. They had terrible knock (7 degrees and more) and it seemed that all other sensors are OK (coolant temp, MAT, idle speed, etc.) The truck runs like crap, has a stocker in and is neither throwing code 13, 44 or 45 which should be common...
M@ (scratching head)
smeagol
When it is unplugged, I believe the 02 sensor reading is about that (mid 400s)
I'd wager there is an electrical problem - bad connection, bad wire, etc, as it mimics having NO sensor whatsoever.
Get a voltmeter and start doing some continuity testing from the ECM connector, to the sensor plug. If you locate some damage, see if there was any damage to the harness that may cause other problems as well.
If you find any, it might not be a bad idea to go through the harness some more with the voltmeter, hunting for wiring/connection issues.
BadTy
Thanks for your helph!
Follows parts I have changet:
Wires
Plugs
Rotor
Cap
MAT Sensor
Wahter temp Sensor
O2 Sensor
ECM
ignition coil (?)
MAP sensor
Engine speed control sensor (?)
The conection from O2 sensor to the ECM is OK
I have - and + on the O2 sensor
But the ECM dont give the signal an the O2 sensor for the closed loop :-(
I`ts allways on the open loop
The Engine runds badly on 800 to ca. 1200 U/min
I down :-(
Roland
smeagol
If you see 443mv or whatever for 02 readings - it is not receiving a signal in the ECM for the oxygen sensor.
If the sensor readings do not transition (toggle back and forth past 450mv) it will NOT go into closed loop.
This is the source of that problem.
BadTy
Thanks for the answer Brian!
But the signal comes up to the ECM. From the plug of the O2 sensor to the ECM I have passage.
Do you now if this signal is measurably?
Roland
smeagol
Do this
Connect your scan tool, run your truck...
plug in and unplug your 02 sensor... see if the values change....
I am betting the readings on the scan tool will NOT change. Meaning somewhere, between the sensor, and the ECM processor, it is NOT receiving the 02. Could be wires, could be plugs, could be internal on the ECM.
You'll just have to spend the time here - If you have checked all wires & plugs, I'd try a proven good ECM or 02 sensor from another truck.
BadTy
1000 thanks for your helph!
it is possible that despite connection between ECM and plug CO2 sensor
the signal is not carried?
I thought if I have conection, the signal can be transferred.
To separate the plug of the O2 sensor change nothing.
Diacom indicates allways only the 447mV
I`am helpless....
Roland
P.S. I have a lot of parts in my workshop. So I can change parts if I need.
TurboTony
Okay, lemme try and help.
Hook up your scan tool, datamaster, whatever.
Key on engine off
Disconnect the o2 sensor connector, measure what you have at the three terminals.
Test terminal A and B with a regular test light.
Terminal A should be around 12 volts.
Terminal B should be a good ground.
Terminal C is your o2 signal to the pcm. you should measure around 447 mV at that terminal.
If all the above tests show ok, replace the o2 sensor, if not post back.
HTH
Tony
BadTy
:D Thanks for the answer Tony
Terminal A has 12V
B has ground
C goes to ECM, pin E14. The conection i`ts OK
All this are OK :evil:
Today I will check if the down pipe an the engine has ground. That`s my last idea...
I have changet so many part! I`ts incredible!
Roland
helfmann
Don't rely on Diacom, take a f*cking multimeter and MEASURE!
If the PCM/ECM is shot OR the wire resistance is too high, Diacom is useless... listen what others tell you! javascript:emoticon(':agrue:')
I provided you the whole circuit test procedure, there is nothing written in regards of Diacom. If the ECM does not throw code 13,44 or 45 you need additional but very basic and simple tools.
M@
BadTy
I`m checked the ground and + with a multimeter. The conection too.
Today I will check if the signal from the O2 sensor arrive to pin E14 an the ECM (by multimeter :D )
Roland
helfmann
Perhaps I was a bit harsh what/how I said...
I wanted to state that Diacom, Datamaster is reading data AFTER the ECM through the ALDL, you are interested in what is going TO the ECM, to narrow the error down to a sensor and/or the ECM. Worst case s'thing is wrong between ECM and ALDL. These cases can only be investigated with additional tools. You HAVE TO define the baseline, these are the wires from the sensor before they reach the ECM.
M@
BadTy
@ Matt
I know you already so for a long time that I know, how you mean it :wink:
I will change my search to bee "before war methods" :D
I`ts possible that so i can find the error!
Thanks for your constantly help over all the years!!
Roland
BadTy
CA on 7. June at the European Gathering!
Than I brines your ass :D
I`ts time to get on bet for you! Tomorrow begins a new work-ritch day for you! :fist:
Roland
