No oil pressure
Jeremy
I have no oil pressure and I'm pretty sure the oil pump is good. I want to test the circuit from the sensor to the gauge. I have three wires coming off the sensor- light green, yellow and orange. Any one know which wire I need to test? Most likely the cause. Thanks.
turrrbo6
Re: No oil pressure
Make sure the needle in the gauge didn't jump around and is now resting under the pin.
yar
Re: No oil pressure
look at the pin @ 0 pressure and see if it has the pointer sitting next to it,if so it has jumped the pin @ 60 lbs and came all of the way around
Ray
Jeremy
Re: No oil pressure
Yep, the needle is on the back side of the post so to speak. I'm guessing this is a common problem so if someone can point me to the thread already started Thanks for your help. Glad it was this and not a bad sensor/sender, that would be a pain in the ass to replace.
