NO silicone on intake gaskets??
Ty 1885
My intake gaskets started leaking water soon after i started my new engine!
The intake is strait and at the right angle. Was told by machine shop NOT to use silicone on intake gasket, use 3M yellow sealer. Also i need to use a thicker gasket .090 or thicker because the intake been cut several times (had to longate the holes to intall bolts).
FELPRO tech said to use a thicker gasket because i dont have enought clamping force on the bottom of the intake due to the bolts being higher on the manifold (due to cuting several times) I dont know if that makes sense:dunno:
What do you guys think??
bezerk
Re: NO silicone on intake gaskets??
if you got vortecs you must use RTV on both sides of the gasket. waterjackets ALWAYS, i like to do all the ports
Icarus-54
Donating Old Member
silicone around the water ports,edelbrock gasachinch on the rest
Ty 1885
I've always used silicone around water ports in the past, but now EVERY one FELPRO, SCE Gaskets, MR GASKET saying that they have problems with gaskets leaking or blowing out do to silicone use!
They ALL said to use automotive cement sealer.
bezerk
never had a problem.
bezerk
btw even when i'm to bored to check for gaskets i just use RTV between waterpumps and block without problems. no gaskets at all
blacktyaffair
btw even when i'm too lazy to check for gaskets i just use RTV between waterpumps and block without problems. no gaskets at all
Fixed. Silicone around the water ports should not hurt the other ports.
