Does it work if you jump it at the test terminal on the firewall?
The fuel pump will run even if the ECM B fuse is blown if you put 12 volts to the test connector.
"Applying 12 volts to fuel pump test connector to troubleshoot fuel pump or set fuel pressure with vacuum line still connected and motor off (note fuse for safety)."
All fuses are good. Tach does not jump when turning it over. So far no luck.
Ignition module.I think they're like tree fiddy at Auto World.
Dist is bad.done put in a new module. i am stumped...
