No-start condition and ignition ???s
Sy Guy 0024
To make a long story short, I was heading home from heavy breather's house last week when my sy died. Wouldn't start back up for anything. No fuel pressure (other than the 2 second prime from the fp relay) and no spark (my tach wouldn't budge as I cranked the engine). It seems as thought the ECM is receiving no reference signal from the distributor. My oil press gage also would not leave "0" as the engine cranked. I've been tinkering with it ever since, but can make no progress on it.
So Mike H hooks me up with the 92 sy/ty/sogt supp manual. I'm following the ignition system check on page 6e3-c4-5 when I come to a snag. It says to pull the 3-terminal "C/+/B" connector from the distributor to check with a multimeter. Well on my sy, the only connectors to the dist are a 2- and a 4-pin. Is this a misprint in the manual or are the 91s the only trucks w/the 2-pin connector? Both wires lead to the coil on mine, so I'm wondering what the 3rd wire mentioned in the manual leads to. A ground? Any thoughts on this?
Also, any idea why my truck won't start? My fp relay is good and I've replaced everything in the ignition system except the magnetic pickup coil in my msd distributor (which I'm gonna replace tomorrow). My ecm is good, as we drove to JS Design on it installed in Mike H's ty. Don't know what else it could be? Pretty stumped here, so any thoughts are welcome.
Corbin
ghettosled
SYTY SUPERSTORE
I would suspect something more simple. Possibly a fuse, or ground? I would check to make sure your purple wire to the starter is getting 12v, and check to make sure the wire from the battery is sending 12v as well. Pull the coil wire and check for ignition, and see if your fuel rail is holding any pressure.
Just a couple things to try.
ed hess
race or get outta the way
well if you say you get no fuel pressure even after hearing the pump run for 2 seconds. I would say, either the fuel filter is clogged or the pump is laying at the bottom of the tank or the regulator is shot.
ed
Sy Guy 0024
Well, I think I found my problem. Replacing my pickup coil made no difference, so I pulled the dist cap back off. Had the wife crank the engine while I watched the rotor button. Fuckin thing doesn't even move (well it slightly nudges, but it goes no further as you crank). My guess: broken distributor shaft. What do you guys think?
I can actually turn the rotor button about .5" by hand until it hits something and stops. Either the dist has worked itself loose until the cam gear disengaged or the shaft snapped off.
Not sure why this kinda stuff happens to me? This truck has been pretty frustrating so far. :banghead: :banghead: :fist:
I guess it's not so bad though, as I'm getting ready to pull the intake for the vortec conversion this week anyway. But damn, this is gettin ridiculous :-?
Corbin
Jimmy
Banned
Corbin
Oh man,you didn't know that these trucks are posessed by Satan himself? :evil:
Trust me,we all have love/hate relationships with our trucks.
