no start...
skipztt
boost
put a brand new battery in the ty. literally just 15min ago
the truck has always started up for me.
so i hop in and turn the key.. all it does is crank over. i can hear fuel pump prime, ic pump run..etc. just wont catch.
i noticed the tach doesnt jump.. it makes me think its either a coil or ignition module.
ignition module is some what not too old.... around 2 years old.
how can i test the coil??
dont really fell like pulling the dizzy out and replacing the ign module:tdown:
any ideas??
NJ93TY
Re: no start...
Did you confirm yet that you have no spark? Use a spark tester and check it off the coil wire first.
SY2932
Administrator
Re: no start...
This is how you can test the coil:
"This is a brand new MSD coil #8226. The coil does NOT have to be removed from the vehicle to perform these checks. Any connections on the terminals will have to be done with a paperclip or other small object as the test leads won't be able to reach the pins inside. This value should be infinite resistance (open). If not, replace the coil."
"From here on out, the resistive values are not "carved in stone" and are approximate. Here, the value should be very low or zero. If not, replace the coil."
"Here, the resistance should be high but, not infinity (open). If not, replace the coil. *These checks will work on a stock coil as well*"
HTH's
skipztt
boost
Re: no start...
thanks jersey and mike...
ill try that out, im hoping its just the coil...but we will see.
ill update this later and post results
skipztt
boost
Re: no start...
first i put a new coil in it.. it didnt help, but i have never changed the coil in it since ive owned the truck. so at least now i know theres a new coil in it.
went to autozone and asked if if they had a ign module in stock. they said yes.
i told them i bought one no too long ago (2 years ago). the guy looks up my name and, yes, i did buy one from them.
matter of fact it has a lifetime warrenty on it.. SCORE! lol
i go pull the old one out, kinda of a pain, but not too bad. head back to autozone, get a new free ign module. put it back in.. truck fires right up!
problem solved!
Sy-1177
Turbo Inside
Re: no start...
problem solved!
Right on man! Did you put that white grease on the bottom of it? You may have burned the other one up if you didn't.
skipztt
boost
Re: no start...
yes i put the white grease on both of them.
best part is.. when i took the old one to autozone. they ran it on a tester and it passed. :roll:
but the guy gave me a new one anyway.:tup:
tydye
Banned
Re: no start...
maybe the connector was bad and they got a better connection then you? just guessing and looked like you got off easy :)
SY2932
Administrator
Re: no start...
That is why I always have them test it more than once. The more that they test it, the hotter that it will get simulating the conditions that it experiences while on the vehicle. The ignition modules on a 454 BB RV and 2.8 S10 that I worked on earlier this year passed the first time they were tested. However by the third test, they both failed. In both of those cases, there were problems once they got to operating temperature. Your situation was different because you couldn't even get it started... I had the same problem with my truck after it sat for more than two years transmissionless. Glad to hear that you got it figured out :).
