noise coming from distributor
kwick6
started the truck up today, been sitting most of the winter.
noticed a strange sound while sitting in drivers seat.
so I get out, pop the hood, and it seems its coming from under the distributor cap.
hard to describe the sound, but its sounds as if its associated with the spinning of the distributor.
anyone ever have this?
TIA
Scott
Loeryder
Could be arcing if it got some moisture in it while sitting.
Pull the cap clean it with WD 40, if its accel just replace it.
kwick6
accel .......::backhand:: LOL
seems it went away after I drove it.
I did some browsing in the archives, saw some have rebuilt them. What would be a reason to do so.....high mileage, nothing better to do.?
thanks, WD 40 sounds much easier for now tho. :roll:
Scott
kwick6
warmpancakes said:
scott, if ypou need to borrow one swing by mines sitting doing nothing. ken
thanks, I think its okay. what else you got laying around doing nothing.. :p :D :eek:
Loeryder
FYI
New distributors are no longer available so even if you buy a GM unit its gonna be reman'd.
If you use the AutoZone distributor replace the Ignition Module with a GM / AC Delco unit # 16139369
Also make sure it has the bronze gear.
And the noise in Kwick6 truck was actually his gerbil got loose.
But he'd never say that on here... :lol: :lol:
kwick6
alright, I think the noise was just do to it sitting for over a month....
not due to any small rodents as someone here claims. I would never own one of those, unless I had a snake or something to feed it to. :eek: :D
