Noob With A Knock
Dr.T
Going to keep the as short as possible.
I bought the truck about a month ago, no knocking noise, drove it home, noticed it was overboosting so I didn’t really lay into it. The guy I bought it from was a jackass (should have noticed there would be a problem from the beginning):oops: He said the engine was just rebuilt? but with no papers. It has a full exhaust, headers, new stock turbo, MSD full ignition except wires, and he said the previous owner put in a cam (cant hear any loping at idle). I figured I would take it to my mechanic before really driving it hard, to do all the basics and go over the truck. I Used the truck a few times just driving normally maybe a hundred miles or so, hit boost a few times but as before never really drove it hard.
Now I have a knocking noise, and I’ve been searching here and tried ruling a few things out.
About the Knock: You can hear it from outside and inside the truck.
Sometimes it goes away completely.
It increases with revving.
Its not a loud clunking noise, but not an injector tick.
It doesn’t affect power.
I Checked the oil- looked a little dirty, asked the owner when it was changed and he didn’t remember? And said it wasn’t synthetic? :rant:
Oil pressure looks good based on the crappy gauge in the truck.
When I brought it to my mechanic to check the knock, what we did was pull each plug wire while the car was running: when we got to cylinder 2 on the passenger side, the knocking stopped.
He also said it does look like the engine was recently pulled.
He thinks it’s the wrist pin, and the previous owner put some additive in it to quiet it down. Does this sound right? Could it be anything else? It does I guess make sense that when you stop spark to that piston the noise stops.
Please help, my ass hurts from this whole deal.
Dr.T
Re: Noob With A Knock
Thanks for the reply
That reminds me that it also has a stronger rebuilt transmission with a torque converter and shift kit.
But why would the knock stop when the plug wire was removed? If it was the torque converter bolts wouldn't it still be knocking?
Windedv6
Ty n 10s
A good turbo cam may not have a lope at idle. It will depend on the amount of overlap it has. Most turbo cams run 114* to 116* Lobe Separations and lower durations to keep the over lap low. This is to close the exhaust valve when the intake valve starts to open. A NA motor like just the reverse. They want more over lap so the exhaust came scavage more air through the cylinder and intake. This is where you get your lope sound.
Your knock sounds like a wrist pin or rod. The noise went away when you took off the load by unhooking the sparkplug. I have replaced a couple of pistons without pulling the motor in our trucks before. If its not a high Hp setup it could be worth doing it that way. On the other hand it sounds as if you have no idea whats currently in it so maybe you need to pull it and redo it. It shouldn't be that bad if you haven't hurt anything yet.
John
Dr.T
Thanks for the info. I'm going to have to figure out what to do? My options are either pull the engine and go forged internals, just fix the bad pin or piston, or sell the truck as is and take a loss.
My wife wants me to sell, she's hated it since the day I brought it home:lol:
BoostedSUV
Pretty sure overboosting didn't help... Was it tuned for work that was done to the truck? Shift kits are def a "no no" for these trucks as well. I really hope you didn't spend too much on the truck because it already sounds like you're in for a lot more money. Welcome to sy/ty ownership! Lol
Dr.T
Yea thanks man:lol: I'm not into it too deep yet....The guy that had it before me got it from someone else who did the work, so he really had no idea about anything. As for the shift kit, it hits through the gears pretty hard, and I've been in a few cars with shift kits so I just assumed this has one? Also verified by my mechanic when we drove it.
As much of a pain in the ass this truck, plus many other cars I've owned and own have been, can't help it...its all part of the fun:D
