normal vac pressure on 2 bar?
.Boston.
Hi I was wondering what the normal vac pressure at idle using a 2 bar map i have a Sy and it stays on 15 at idle is this normal or should it be around 20?
Thanks
92TyLA
Re: normal vac pressure on 2 bar?
well accordin to my aftermarket boost gauge its aroung 20-18
and it idles perfect
also is this your first post EVER!
sharkbait
seems to be his first. in which case he should post the usual intro stuff, truck number (last for of vin), where your from and some pics.:lol:
jeepruby04
The gauge in the dash is a piece-o-shit, but it will say -15 at idle which is about -20 in the real world.
On an aftermarket gauge it should read 18-20" by unless someone has changed the camshaft.
.Boston.
sorry about no intro lol but ive been doing research on this forum for over a month just never really had a need to post, anyways i have an aftermarket boost gauge and its reading a constant 15 psi at idle, there were a few mods done by the previous owner but nothing that would alter vac pressure im guessing vacuum leaks somewhere around the intake mani and have found several when i first got the truck but it should all be sealed up, i have looked in up and down..
KBowman
I would verify the low vacume reading with another gauge. It needs to go directly to manifold vacume. I think at 15 instead of 20 you would have a rough idle. It should be 20-21 if everything is right. Verify that there is no vacume leak and then if that checks out I would do a compression test as the motor is basicly a big air pump and if it has low compression that would cause a low vacume reading.
.Boston.
alright sounds good im going to get my friends gauge and hook it up to another line later today, ill let you all know whats up later on
Warning :rant:
You do not have "15 psi" at idle. You have 15" (inches of mercury - vacuum). Big difference. If the gauge read in pounds, on the vacuum side, which it doesn't, that would be about negative 1/2 lb. Only when we go into boost does the measurement unit become PSI. (Pounds per Square Inch)
TMI to follow...
30" of vac would be close to perfect. As a naturally aspirated motor approaches full throttle vac drops to near -0-. With our trucks only then do we transition into boost measured in PSI.
Although we don't do it it's common to measure boost as inches of mercury as well. Piston powered aircraft (excepting fixed pitch propeller types.) use absolute pressure in inches of mercury. IOW if I had a turbocharged aircraft running, say, 5 pounds of boost I'd see about 40" (inches of mercury) of manifold pressure (not vacuum).
At rest, engine off, at sea level, I'd see about 30" on that aircraft gauge. In our trucks we see -0- (no vac, no boost).
So to avoid confusion it's helpful to keep our measurement units correct. You're not alone here. These are common misconceptions.
.Boston.
Warning :rant:
TMI to follow...
ok well sorry i only used it once by mistake and i guess thats cool but i dont own an aircraft and just own a syclone lol which is not my first turbo vehicle and that is why i ask about the "15 on the vac said of the gauge" 20 was normal for me in most of my boosted cars and my altitude where i live is roughly 3,200 ft
ps you really didnt help me with my question in my original post, what would you recommend?
The aircraft analogy was just to try to explain the point. Like I said, mostly just flapping my jaws anyway.
Your question: OK, 2bar or 3bar is irrelevant unless you're looking at the stock gauge which works only with a 2bar. Assuming stock cam then as mentioned closer to 20" vac would be better. If idle is smooth (these things never idle real smooth) then you're probably OK. Vac leaks usually cause an increase in idle speed in my experience. Take a vac line off and see what I mean. Leaks can be numerous places.
Bad vac line or connection or check valve. We have lots.
EGR valve not closing
Throttle body gaskets, Top and/or bottom, or where it bolts to upper intake.
Throttle butterflies not closing all the way. If someone has tried to adjust idle with the throttle stop then that is likely. Butterflies need to be closed at idle so the IAC can control idle.
Gasket between upper and lower intake.
Have the injectors been out? Then maybe an inj 0-ring on the manifold side is twisted or cut. (This is a long-shot.)
Blown intake gasket. This can be hard to diagnose.
All I can think of right now.
.Boston.
awesome thanks!
I blocked off the EGR valve but the piston could be stuck open? and the car idles smooth stays at 800 rpm maybe bad gaskets or the injector o rings i have to look those over
awesome thanks!
Blocked off as in removed or just vac line disconnected. Only way to be sure is to remove it and maybe try to clean it. I attempted to clean mine once, didn't help. Eventually just removed it an put a plate on there.
EDIT. I had a blown intake to cyl head gasket on mine. Do a search on testing for leaks with a bicycle tube. I could hear a leak but couldn't find it. Finally bit the bullet and removed the lower intake and gasket was gone. Here's the link:
http://www.syty.net/forums/showthread.php?t=50844&highlight=intake+gasket
awesome thanks!
Your Idle should be lower than 800rpm.
