Sy Guy 0024
I just finished head gaskets on my Ty, and when adjusting valves I noticed that the amount of oil flowing from the pushrods seems low. It seems to be just slowly seeping out and down over the rocker arms with little force.
When I adjusted valves on my Sy, I remember the oil squirting out all over the place and making a smoky mess.
Should I be concerned over the difference in oil volume from one truck to the next? The idle oil pressure reads the same now as it did before the teardown (around 60psi on the lame stock gage), but I didn't run the truck with the valve covers off then to see how the oil was flowing. Is it normal not to see much oil flow at idle?
