not sure how to label this
syclownz
Really need some help/advise in this matter. I get backfire occasionally and (don"t know if it is related or not) sometimes while sitting at a light the truck will lunge forward and the check engine light will flash on for a quick second but it will not store the code.
I recently done a tune up with wires since one was arching to the exhaust manifold. Replaced cap & rotor with ignition coil (warranty) to rule it out. NGK R UR6 with taylor wires and new o2 sensor.
I also tried disconnecting all the sensors while in idle and no change in behavior. Someone told me to try it so i did.
Any thoughts?
syclownz
Re: not sure how to label this
I'll have to try to count the iac. It's brand new as well. I only have access to a snap-on scanner. Not sure if it will do the counts?
The backfire is out the exhaust and it usually happens around 2 thousand rpms. I am not in boost when it happens. I could be going anywhere from 20-35mph when it decides to happen. It usually happens in traffic just when i pull next to someone in a new car with their windows down :oops: Also, the fuel pressure is around 34-36 at idle.
The boost gauge i have now is a SPA boost/egt gauge and it seems to only read -8 vacuum at idle. Just doesn't seem right so i was gonna get rid of it and get a analog gauge instead to maybe help me read vacuum to see if i have a leak.
Idle has always been rough (bouncy needle) from day one. Even on it's best days. When i replaced the plug wires it got so much better but the occasional backfire is still there and so is the forward lunge and CEL flash.
My first suspicion is cross fire. (Spark is "induced" into the wrong wire and fires the wrong plug. Or arcing in cap) I know, cap is new, wires are new. But if, for example, one plug is bad causing very high resistance then an adjacent plug may fire.
Tough to track down this stuff. Look inside cap and inspect for tracking between terms. Make sure all wires are fully seated in cap and on plugs. Make sure wires are not touching each other for any length. Check plug gap and while you're doing that make sure there are no cracked insulators.
And as Dave said you ohm out the wires a see if you have a bad one.
Next idea is a misfiring injector. make sure wires are fully seated on inj. (Hard to have caused this as there is clip holding them in place.)
Check fuel pressure with vac line off although it seems close..
HTH
syclownz
Well, firing order turned out to be right, but now it seems i might have a blown head gasket or intake gasket or something. Losing coolant into and out through #6 cylinder.
Pulled out plugs and turned engine over and water shot out. I was getting misfire (obviously) and it was smoking out the exhaust only on start up. Start driving and it would stop smoking. I could get 15-20 miles or so before the needle would start to climb.
Had to drive to get home. Had a gallon of water with me so i never let it over heat.
Going to do a compression test and see what happens. Hopefully, it is only a set of gaskets that i need.
thank you for your help
vinnieTy
TY # 1889
What is the status on this?
