O2 - Closed Loop all the time
Quickstop [UK]
Combating adversyty.
OK,
went for a drive tonight with a friend to try and sort out some problems.
Reset the ECM by pulling the fuses and all looks good. The we drove off and straight away code 13 O2 fail came on.
We drove around for a bit and randomly it would go closed / open loop on the O2 gauge.
I think it was a wiring fault with my LM 1 as we did a second run and there were no error codes whatsoever.
The problems as I see it is that the second time we were out (20 min) the ECM was in closed loop with the O2 the whole time. WOT / idle / braking / accelerating. What gives?
Incidentally, if it were in closed loop the whole time, trying to pull back the mixture for highway driving, would that cause it to lean out?
The other problem related to this is that I think that it may be causing the mixture to lean at around 100mph and I get a misfire or something. I have a DM file that I would appreciate someone looking over? PM me with your e-mail if you have the time.
Thanks guys.
Daryl H
Re: O2 - Closed Loop all the time
Depending on how you wired your system, the ECM still requires a signal that the O2 sensor is being heated.
Quickstop [UK]
analogue out from the LM-1 goes straight to the ECM. I cut the tails from the old O2 sensor and just connected the analogue out to that.
That was how it advised doing it in the book. Any thoughts?
Daryl H
There should be 3 wires from the old O2 sensor connector.
One for O2 heater element.
One for ground.
One for narrowband O2 mv.
Assuming you replaced the O2 sensor with a wideband, all 3 wires are still used by the ECM which is causing codes.
The easiest way to fix the problem is to hook the original narrowband O2 sensor back into the original plug and leave the simulated narrowband signal going to the ECM via the original O2 mv wire from the wideband controller. The narrowband sensor does not need to be in the exhaust stream since it will only be used by the ECM to verify that the O2 heater element is working. I am not sure how hot it will get so dont leave it exposed to skin or jet fuel.
