O2 sensor and the Phil long chip
akwilks
Mr. Keith
I have the v5 50 chip and when I check my O2 sensor with FreeScan it reads .004 at idle and .1 under load...is this normal? My truck stalls out at the most inopportune moment...yesterday I was in the left lane and it stalled just before an intersection....it took about 5mins before she would start again...luckily I got her home....I understand that I should see .5mv at idle and .9mv under load...so do I have a problem and am I looking in the wrong place? My 2bar chip does indicate normal O2 readings but the 3bar doesnt...
The thrill is gone...I really wanted a typhoon from inception but now I feel out classed...I refuse to destroy this vehicle due to lack of knowledge because they are so awesome..I have checked voltage levels and my engine runs right at 13.2v at idle...I'm really suffering right now so if anybody can give me a remedy aside from selling my Typhoon would be greatly appreciated...(Dont think I havent thought about that because I have)
akwilks
Mr. Keith
Re: O2 sensor and the Phil long chip
No, I have FreeScan scantool and havent seen a mode to switch between the two....I do have a DM but have to get a usb adapter that will work with it...the one I have doesnt recognize the data...
.4 and .1 sound in the range, BUT stock o2 sensor readings can lead you in odd directions. You need to look at several things.
Freescan I don't thing will show 3 bar info correctly. You may try tunerpro also, it is free and uses same cable.
gjp
another post whore
I posted an adaptor in a past post. Works great. Its at Fry's for 29.95. The Phil chip is great. The higher Idle took care of my stalling problems.
