obd1 ipod connector
gibby customs
i just got a i pod touch and was reading on here where i can veiw and data log on it but i cant find one anywhere does anybody know where i cant get one or have a spare they'd sell?
thanks
KETCH-UP
Re: obd1 ipod connector
I have researched this throughly and it is obd II only. Unless someone here has the capability of creating the interface, I doubt obd I will get support. I am willing to look at the hardware possibilities, but the software is the big task.
The Bronze
I use a couple of the the Iphone OBDII apps. There isn't a GM OBD1 out there that is advertised.
henry283
Heres the cable needed to talk to serial devices from a iphone/ipad. As I understand it Apple may now allow some access to the serial port from native IOS applications.
The cable can be used with a jailbroken iphone/ipad to access the serial port with a terminal emulation program on the iphone. Links I found were from sites professing to use this for console access to cisco routers/switches.
http://bestcelldist.com/apple_iphone_serial_data_cable_flexserial.html
henry283
To make this work you'll also need an aldl to serial cable or some other device to interface aldl to 9 pin serial. You won't be able to directly interface to the aldl cable and read it with off the self serial hardware and software. Just takes interest, time and maybe a little money to buy the hardware/software to experiment it's possible I just don't know anyone with the necessary skills.
The main reason obd 1 is not supported is OBD 1 has NO common communication style. GM did different things on different cars let alone between ford, etc. Every OBD1 car needs a different language so to speak.
OBD2 went to a common communication platform. Thats why you can hook up and OBD2 device to any car and it works. Ford, Chevy, Honda, etc.
So now your down to someone making the hardware #1, #2 someone has to write specific code for our trucks. You are more likely to buy a winning lotto ticket.
gibby customs
okay i could swore i read on here somebody tuning with a ipad but it musta been a LS conversion syty o well can somebody tell me where 2 download a free aldl software i only have 4 more uses on data master
Quickstop [UK]
Combating adversyty.
Download Tuner Pro. You can get it free but it's $39 to stop the popup reminder. You can log and tune with that all day long.
