Odd Datamaster reading
manitoufs
I just loaded the latest version of DM (3.4.1) on my new (to me) Dell XPI CD (166 mz). My old Dell crashed. I just got back from doing a couple of test runs. Everything looks normal except for the knock counts.
I began collecting data by turning on the ignition w/o starting the engine. 12 data records after the engine started (it just reached 650 rpm), DM displays 3025 knock counts. The previous record showed zero counts. There were no audible mechanical noises that would have generated this.
Has anyone else seen this? I never saw anything like this with my previous version (an original Beta version from 2000) on my old Dell.
_________________
George Betzhold
93 Ty 2115
91 Mazda Miata BRG
74 Ducati 750 Sport
<font size=-1>[ This Message was edited by: manitoufs on 2002-02-24 10:29 ]</font>
Falco
Yep. It's the same for me. It was good till v3.3.0. When I upgraded to V3.4.1 it started to show knock count incorectly. At every knock it's jumping several hundreds.
It's disturbing, but not that much, I usualy see the retard and not the knock count.
HTH,
crsurf1
Ditto over here. I loaded 3.4 on another laptop and a Datamaster file that shows 6 count on the knocks on 3.3 shows in excess of 3000 on 3.4. That's also just after idle.
I'm sticking with 3.3
Rufus
Hi, all
Take a look in the readme file, you will note that DM341 for the SYTY changed the readout for knockcounts. The old version only used an 8-bit count, while the new version uses the full 16-bit count that the datastream offers. This is why you see counts you did not previously. The old 8-bit count was only the Most Significent Byte of the data.
Note that it is normal to see to count increment ~100 at a time, this is how the ECM reports the data!
Regards,
Gary
