Oh God!!!! Whats Next!!!!
TYTILIDIE
METH HEAD
So Im undoing everything today to take out my motor and I realize that there are only two bolts (driver side) holding the motor to the trans. So Im thinking maybe that was my knocking sound. So I cut open the oil filter and drain some of the oil into a shop towel and there is an ass load of metal in it. So I decide to proceed with removing the motor. I took off the upper intake and noticed a butt load of oil in there. So I look at the turbo elbow and see the same thing. I dont have a PCV system so it had to have come from the turbo itself. So I wiggle the shaft and it moves around ALOT. Side to side and in and out. Then to make things worse, I check the trans fluid and it smells like dog crap. I give it a month or two after I get the truck running to go out. So heres my options, Get the MITSU 20G and do the stall when I blow the trans or have mine rebuilt. Not too sure which way to go. I know its going to cost me $500 to rebuild my bottom end but I just cant afford the turbo at all right now. Rebuilding it may be all I can do. Is this soimething you can do in your garage or is there machining involved?
Mike
Timbo
SyTy Stalker
Re: Oh God!!!! Whats Next!!!!
No machining that I'm aware of, but you will need to have it balanced for sure.
TYTILIDIE
METH HEAD
That suckls cause I rthink there is only one shop in the state that does it. Do you know how much it could cost to have that done?
Mike
Ian Turgeon
Cascading Inspiration
I think you can assume a 20g or regular rebuild to be $200+. The bushings and such from the center section seem to go for right around $100, so tack on shipping and service fees and it adds up fast. 20g will probly be more as they have to replace the comp wheel (mitsu turbo parts are fairly expensive) and either machine or swap the comp housing. However for either of these you wont need a bigger stall converter, only need one if you go to a bigger exhaust housing like what comes with the standard 20g/14cm.
TYTILIDIE
METH HEAD
Dont flame me but what is the difference between what you are talking about and the standard 20g 14 cm? Its the ex housing? Impellar? I guess what Im asking is why do you need a bigger stall for one and not the other?
Mike
Ian Turgeon
bigger stall needed for a bigger exhaust housing, stock turbo is 8cm, theres a 10 12 and 14. The 14 is pretty commonly what you see the 20g packaged with in our application. Upgrading to a 20g impeller alone doesnt require a TC, its all about the exhaust housing/turbine.
The 8 is a little small for the stock converter, 10 or 12 are just about right. 12 is hard as hell to find, so I'd think about a 10 or 14 if your changing the exhaust side.
TYTILIDIE
METH HEAD
Is all this something I can do myslef? Ive built motors and my trans and a bunch of other crap. Ive been wrenchin for years but have never taken apart a turbo let alone upgraded one. If I just go with the 20g wheel, will I gain much or not really?
Mike
I don't know where colorado spring in terms of elevations, but i have read that you may want to use a smaller exhaust housing at higher elevations (ie Denver)
Gmoney
I'm running a 20g with an 8cm housing, stock trans and torque converter, it spools a little faster than stock with a launch and pulls way more on the highway, I'm at 5800feet just south of denver
TYTILIDIE
METH HEAD
What CM are we stock.? I thouight we were 8. Do you by chance know anyone who can do tihs?
Mike
TYTILIDIE
METH HEAD
Well, got the pan off and found out what screwed up everything. My oil pickup tube fell off. Anyone know a trick to keeping this from happening again?
Mike
bezerk
Mike
they weld it
93ty475
typhooner0073 said:
My oil pickup tube fell off. Mike
:eek: damn, that sucks....like bezerk said, welding will keep it together...talk about someone putting together a time bomb....you know what you have to do now....any pics of the devastation? is this the first time it's been apart ?
TYTILIDIE
METH HEAD
I can get pics on here sometime today. Wasnt an incredible amount of carnage. The p/u was slightly dinged. All main bearigns are wavy and some of the rod bearings. Turbo sufffered the worse Ild say. The motor was out last year and I put it together. This was my 6th or 7th engine Ive built and I cant say that I have ever had a p/u fall off. JER called it thoguh when we were chattin about it a few days ago. It makes sense as it took a quart more than normal to hold oil pressure and even then it wasnt right. Off to the machine shop today though. And going to try to find someone to get me parts for the turbo.
Mike
Stock is 8cm2, I would use a 8cm2 or 10cm2 for being a mile high. The larger exhust housing should give better top end. For sea level I wouldn't even think about a 8cm2 housing with a 20g.
Its held on by a clamp, but they sometime are stuck together. Mine easy came apart with one hit with rubber hammer, but I have fair weather driver (very little rain & no snow)with 50K miles.
