OHM readings / Plug wires
Captain Morgan
Moderated User
well im attempting to finish my tuneup in my garage and I decided to test the old wires against the new wires before I put them on.
wow is all I can say.
OHM readings for the new wires were on average 1.90
OHM readings for the old wires were on average 0.74
now the funny thing came when I tested the coil wire.
the new coil wire was around 0.265
and the old coil wire was around 0.279
has anyone else done testing like this with similar results? Im not really familir with how resistance plays a part in a coil to distrbutor wire, but im assuming more resistance is better. In that case, should I put my OLD wire back on and stick the new one in the toolbox for a spare?
Just curious as to some feedback.
Peace.
4C FED
Absolutum Dominium
I think you have your meter set to the wrong scale.
Those look way to low.
Even the low resistance wires are about 40 ohms/foot.
So probably they are more like:
New 190
Old 74
New 265
Old 279
Captain Morgan
Moderated User
New 190
Old 74
New 265
Old 279
ok, your probably right, doesnt really matter much, fact still remains the old coil wire has more resistance than the new one, thats really all i care about.
ed hess
race or get outta the way
hey morgan
I think you should throw the new wires in the can!
they should have less resistance i.e. a lower number reading means they are better not worse.
you said your new wires have more resistance than the old.
Think about this. resistance = how much force you need to push something.
so with less resistance you get more current flowing thru becuase there isnt a crappy wire holding it back.
at least thats my take on the whole thing.
ed
Captain Morgan
Moderated User
ed hess said:
hey morgan
ed
hummmmmmmmmmmmmm..............
ok, then something is fucked up somewhere. its not like im switching to another brand or something. they are both Taylor 8mm Spiro Pros, the ones on the truck are probably almost 2 years old im guessing and the new set I got yesterday.
then in that case, the new coil wire is better all the other wires are shit, lol.
ill retest them tomorrow and get accurate readings and see whats up.
ed hess
morgan
as i recall wheni switched from the old wires to the new taylors.
the old had ohm reading of 1000 - 1200, some where higher.
the new taylors were all in the 600-800 range.
ed
someone will correct me if im all wrong here.
sytyguy
Moderated User
I got curious this morning and decided to ohm out some various wire sets in the store. Here goes:
Stock replacement 7mm Wires - 4500-5000 ohm/ft
MSD 8.5mm Super Conductor Wires - 100-150 ohm/ft
Taylor 8mm Spiro-Pro Wires - 400-600 ohm/ft
Moroso Blue Max 11mm Wires - 600-750 ohm/ft
I tested every wire in the set and tested 2 sets of stockers, 2 sets of MSDs, 1 set of Morosos, and 6 sets of Taylors. This number is the average of the tested wires (respective to brands). Surprisingly, the Taylors and Morosos tested out slightly less than what they are advertised at, and the MSDs advertise less than 50 ohm/ft but I just couldn't get a reading that low (not that 100-150 is bad :wink: ).
I'll test more as I get other sets in (Moroso Ultra 40s, Accell, Mallory, etc....), but these are the wire sets I have at this time.
Have any of you ever ohm'd out 77 wires?!? :cry: The things I do for this community.........
Michael
Honestly the difference is negible with an extra couple hundred ohms in the spark plug wires . I don't think their is even 1amp of current going through, but even with 1 amp current corresponds to a drop of 200v getting to the sparkplug with an additional 200ohm in the spark plug wire (our coils put out over 40,000V).
Captain Morgan
Moderated User
Michael
:eek: :eek: :eek: :eek: Damn........I think your new nickname will be Captain Insaneo :lol:
BTW My ATR wires were around 400-500 ohm when I measure them last fall. The stock wires were around 3500-4000 but I am not sure how used they are...
