warmpancakes
do we really need this thing? Id like to dump it to free up some clutter under the hood, I think its only there because of the 4x4 and off road, the syn oil should have the turbo covered
I was wondering the same thing earlier when i was actually working on my sy . Relocating my filter housing to the frame and would like to lose the hoses up to the radiator .warmpancakes said:do we really need this thing? Id like to dump it to free up some clutter under the hood, I think its only there because of the 4x4 and off road, the syn oil should have the turbo covered
WyoSyclone said:If running a water-cooled center section on the turbo, I'd say probably not... the water will pull most of the heat out of the oil... If not running an H2O center I'd say needed... just my :2cents:
WyoSyclone said:To add to my own post...
...really kind of depends on how you drive it, too... If you drive for 20 minutes at 150mph you'd better have a cooler. Any extended high HP driving will require a cooler (rally, a night at the strip, etc.) ...
I would think that a lot of us don't drive hard enough on the street to need one all the time, but for those times we get a wild hair I guess it's an insurance policy - and the turbo is definitely going to add to the heat stress.
Since oil is an incompressible liquid, pressures should stay the same throughout the system unless you cavitate the pump, lose suction, crack a pickup tube, etc. I worry about flow (I've heard rumors that our remote mount filter housings are a 'flow' restriction).
One has to wonder how much heat is added to the oil by running the filter lines alongside the driver's side exhaust manifold for 14"!!
