Re: Oil Diagram
I apologize for deleting a post you found useful. They usually aren't missed.
I don't recall the details, but I do recall the big block pump. I also remember that my thoughts at the time were that the big block pump was set up as a scavenger pump, and that there had probably been an external belt-driven oil pressure pump. Ie a dry sump system. Ther in-sump pump eptied the sump into a tank, and a single-stage Weaver supplied oil under pressure from the tank to the engine.
Front oiling should work as long as the passage from the fitting to the gallery is at least as large as the gallery itself. And that the front passage intersects the driver side (larger) gallery. Put you oil pressure gauge on the rear of the block so you monitor pressure at the furthest point from the pump.
Keep in mind that ALL the power the engine is making goes past the rear main bearing. And that the crank gets bent up pretty good when making power. Wit front oiling, the bearing with the most load on it is furthest from the oil source, so if there is a momentary lapse in pressure, the rear main will be affected first. This is probably the aspect of front oiling with a wet sump that bugs me the most. If something goes wrong, the rear main is toast. With rear oiling, the front bearing is furthest from oil, and no power at all is going by it other than belt load. Get a burble in pressure on a stock engine, you'll probably never know it.
Engines at this level are usually built to race for money. So they have to be reliable, and "work". The chassis loads from acceleration, cornering, and braking are very high compared to street usage. Oil starvation at the pump pick up is a common, fussy problem in race cars. The solution is dry sump. Adds complexity and expense, but it's rock- reliable once set up properly, and the belt stays on the pressure pump.
IMO which end to put the oil in is only a small part of the puzzle. The absolute, bottom line goal is to supply the bearings with uninterrupted oil supply at all phases of the car's operation. Launches as hard as this build should give you will force the sump oil right up the rear wall of the pan and block. There's a point where wet sump just isn't adequate any longer to keep the pick up covered.
Conclusions:
Front oiling is fine on a dry sump.
Front oiling will work on a wet sump, but the pick-up can never be allowed to uncover at high output.
If wet sump is it, be sure your windage trays, scrapers, and baffels are correct. As hard as this thing should launch, it HAS to be, or you'll have oil-starvation bearing problems.
