Oil Dip Stick Install???
autoaddictions
Can you install the oil dipstic after manifolds are in place. I forgot to install dipstick now the hole engine is in and wired up i need to install stock dipstic can this be done?????
QWERTYphoon
Motley Driver Award 2009
Re: Oil Dip Stick Install???
I am not sure if this helps, but this months issue of Street Thunder has a tip on page 18. I had a leaky dip stick in my S10 V8 Blazer and I did this trick and it worked, (I had a little leak). I was able to remove the dipstick and re-install it using a the closed end of a box end wrench. My guess is "Yes"!
Jamerjoe
Yes it can. I have done it before. You just have to remove the 4 spark plug.
autoaddictions
Ill try that. Thanks it bolts to the 2nd manifold bolt from the front to back. right ???
Jamerjoe
The dip stick mounts to the block above 2nd manifold bolt from the front to back with a 10mm bolt.
gjp
another post whore
I did the same thing and had to take the manifold off. I guess if I bent it a bit I could have made it work.
autoaddictions
I had to remove the manifold it was a bich to push in buts its in now. !! The 10 bolt in the head to hold it in is only on the stock heads. If your runnning the newer style vortecs youll have to make a bracket to hold it.
