oil dip stick need asap
Raist103
here is the deal have the entire motor installed forgot the dipstick, i broke 2 stock ones trying to get it in and i am not removing the manifold. does anyone maybe a vender know what the part number is for a flexible dipstick. i need it asap so i can order it and drive it this weekend.
sy#2921
BAMF
Re: oil dip stick need asap
I have a lokar flexable dipstick for a small block laying around. If it will work let me know and we can work out a deal
Raist103
i would think they are the same, what is the length? i need it around 24" if it is close to that i can do 25 shipped tonight.
let me know
don
Raist103
or if any one know the oil hole size, a small block is .370 i dont have a caliper to measure anyone have a block handy to check for me?
Windedv6
Ty n 10s
You may run into a problem. Depending on the 4 bolt cap, the dipstick will hit the cap and not go in. If you don't use the full tube length inside the motor to clear the crank the dipstick itself may get whipped to death or broken inside the pan. Best way to handle it now is use the Lokar tube and leave the dip stick out except when checking the oil. Just use the handle to cap off the tube. You can detach the Lokar dip stick shaft from the handle easily. Be sure to measure the correct length against you stocker from the block to the tip and cut it accordingly. Good luck!
John
Raist103
yeah that was the plan. i dont normally check the oil i just change it every couple months since i dont put any miles on them. i normally change the oil after 1500-2000 miles max. that is normally 5-6 months. the 93 i have, i have less then 1500 miles and 2 oil changes in the last 7 months or more.
