Oil filter adapter leaking???
Gmoney
Walking to the Ty after work today noticed a big oil leak. So when I got home I sprayed the underneath and waited to see where it might be comming from. It looks like right where the remote oil filter adapter connects. Is there a gasket or o-ring or something that could be bad up there?
Bill Z
Re: Oil filter adapter leaking???
If you are talking about where the remote oil filter adapter connects to the block, yes there is an O ring and a flat gasket. If you are talking about where the oil filter lives on the inside of the driver's finder, the only gasket there is what comes on the filter. Also, where the lines connect, there are gaskets on the lines (some sort of simese O ring thing).
Hope that helps.
Gmoney
Ya I'm talking about where it connects to the block. Does that adapter tend to leak alot on other trucks?
GarnetTy1473
Just about every 4wd GM truck I've seen with the remote oil filter, that adapter leaks at some point. Parts are cheap for it luckily, unlike everything else that needs fixing on these trucks.
SY2455
70's Veteran
They sell a kit at any dealer for $5.00 that has the gasket and two O-rings that you need.
