Oil Filter Bypass Questions
Mingus
Hi guys,
I was going to change my oil yesterday so I took the Ty for a drive to warm it up. When I went to remove the oil filter, it was cool (as well as the lines back to the block and to the radiator). I thought maybe I didn't let it warm up enough, so I drove it around more and still had the same issue. The lines don't appear to be blocked and if I crank the engine, the oil will circulate slowly to the filter adapter, but it doesn't seem to go through it when it's running (around 60 psi on the stock gauge).
After a bunch of searches, it's looking like the bypass valve in the block is either missing or stuck open. I read a bunch of threads about ditching the remote filter and cooler. Since I have to pull the adapter off the block and check, I am seriously considering doing this. One of the hoses weeps and I won't have to buy new ones go through the "joy" of changing them.
I also read that stock in-block bypass valves are 11 PSID, but the Sy/Ty ones are 21 PSID because of the remote filter/cooler. If I go to the on block filter, should I buy an 11 or 21 PSID valve? Also, does anyone have the part #'s for the valves? I have the ones for the filter and adapter from the other threads.
Thanks,
Mingus
Re: Oil Filter Bypass Questions
Thanks. Do you have any idea about which bypass valve I should use? DaveP mentioned in the thread that the one in the block was higher pressure differential than the remote filter adapter valve. I found the 11 psi differential and 21 psi differential values used in my first post in another thread. My block one is either missing, stuck open, or I have a plugged line and it is seeing more than the 21 psi difference. I plan on changing it regardless. It seems like nobody has had problems with the stock 21 psi valve after ditching the remote filter, but should I get the 11 psi valve since the filter on block engines used those stock?
atkonkler
Is this your bush?
If it's any consolation....never even touched mine....just got the adapter and removed all the oil cooler system and called it a day....no issues as of yet as I bet others here have also been issue free running the stock setup pressure as well!
Damian
Just buy the adapter. Your pressure will be a bit lower but its.perfectly fine.
Mingus
Update: I know this Ty has had an "interesting" past and now it gets another chapter.
People on 'ludes shouldn't build engines......
My suspicions were correct about why the remote filter and lines weren't getting hot. There was not a bypass valve in the block. So I feel better now about putting the filter on the block and not running through a cooler. Apparently it hasn't ran oil through one (or the filter) for years. I was afraid to see what was going to come out when I drained the oil. Amazingly, there was a very small amount of material on the magnetic drain plug. I actually have a little more indicated oil pressure than less on the stock gauge since it is going through a filter now (about 65# cold vs. 60# before).
BTW, I did verify that it is an 11 PSID valve in the remote filter adapter and a 21 PSID in the block, which is what I used. The part # is 25014612.
ChiPhoon
Chicago Typhoon!
sorry for throwing this question here, figure i ask since on the subject, but for you guys who deleted the remote oil filter housing have you noticed a difference in oil pressure and how much less oil are you using?
atkonkler
Is this your bush?
None that I can tell...been oil coolerless for almost two years now. I'm using about 4-4.25 qts in a oil change. And it runs the same oil filter as my bonneville so i only need one type of oil filter! To your health! Ya dingus!:tup:
Mingus
In my case I'm seeing a little more oil pressure since I had no bypass valve. From the reading I did before working on mine, it sounds like most guys lose some oil pressure. I would guess that it's actually circulating more oil through the engine though since it's not climbing a couple of feet in elevation and going through 10+' of hoses and the cooler.
Mingus
Time will tell if the engine got hurt from not having a bypass valve. It was getting lots of oil flow but was not filtering it. The only threads I could find about the engine being removed were from 2002. It started out as a McCoy "perfomance plus" and then supposedly had 2 different Washington state shops work on it. It would be interesting to know which of these "professionals" left out the bypass valve. It could have been worked on since then by someone without being on the site too.
