Oil filter relocation kit? or what??
G
Guest
Guest
Hay guy's what are people doing for oil relocation.
My hose/tubes have bein leaking for a while,So I ripped them out.there no good now. I was curious how people have solved this problem. new filter relocation kit or braded lines stock lines? What is the best way to fix this problem. Pics are cool.Pm
Thanks
Dan Cheatham
jwaller
Evil Genius/SyTy Guru
this is what I did with mine.
then I took it all off and put the filter back on the block where it should be.
G
Guest
Guest
Sweet nice john :D . What size hose did you use?
did you over tap the hole to keep the same diam to the block.?
Dan
jwaller
I used -8. drilled the adaptors on both ends to a 9/16 and tapped for 1/2npt.
I'll get a few pics of the rest of the setup tomorrow.
jwaller
yes. I've got a oil temp sensor on the line coming out of the blcok feeding the turbo. It never goes above 250. 220 is about where you want it for the most hp.
leroy
Great information John. I'm also curious about when you see the highest oil temperatures.
Thanks.
Jim
jwaller
the oil temp really doesnt move much as I have a 7.5qt system. and if I had to guess it would be just after a 1/4 blast.
skata
john,
did you notice any increase in oil pressure by removing the remote lines?
i always wondered how much the oil flow gets restricted with the remote filter lines.
i used to run a filter on the block, but its damn small and i was worried about oil temps.
jwaller
the block filter is the same as the remote filter. and no I didn't see any differance in oil pressure.
I did run the no cooler setup with my stock oil system and I remember the temps being about the same as they are now.
but with the cooler installed the oil temps followed the water temps by +10 for the oil
so if you ran 160 water. 170 for the oil.
now I can get the oil hotter and make more power.
Lynn D. Brown
John,
How did U fit an Oil Filter on the block. It looked to me like it would run into the Front Diff. ? Did U go 2 WD ?
Hey, Don, R U related to those guys in the Law firm, Cheatam, Cheatam and How ? U probably heard that one before.
jwaller
I use a 4wd propshaft. and with that shaft and pinion flange it's a perfect fit on the block with a pf51.
skata
lynn d brown,
all you do is take the remote lines off, then thread the oil filter adapter(looks like a threaded piece of 1/2" pipe) into the block. then you get a shorter gm style filter(i forget the filter number) and screw it on. that's it.
G
Guest
Guest
Lynn D. Brown said:
John,
Ha ha, Acutally it's Dan But ya I have herd Dewy,Cheatham and Howe a million or so times. The name is cooll with the guy's but girls always ask me "why do they call you cheatham?"
