oil fitting for 20g turbo
jbone
does anyone know where to get the fitting for the oil inlet? Or at least what size it is? to go from the stock oil inlet line to the 20g. I tried home depot, lowes, autozone, and every other parts store around me and found nothing. Thanks
gjp
another post whore
Re: oil fitting for 20g turbo
Try mike at RPM. He has some for the turbo's they carry. Might have that one or know the size. Search for a local shop that sells fittings. I found a shop in san jose called "royal brass" they have tons of fitting and had all for my truck except he was out of stock for one for the turbo but RPM had it.
Quickstop [UK]
Combating adversyty.
does the stock one not work ok? My 20G needed nothing extra after I took off the 17?
How did that gasket template work for you?
jbone
the stock one is bigger than the one in the 20g!! I was under the impression it would work without anything else, but found otherwise in a couple of situations. The gasket came out great but shortly after making it we found a perfect gasket off of an srt4 that was a lot thicker so I ended up using that, but thanks!!!
jbone
ok figured it out I just simply needed a -3 to -4 flared union, and a double female -3 swivel. should be done by tommorow!! :tup:
