The Devils Own Chariot
I did some searching and could not find an answer. Im considering putting the oil filter right on the block. But I do like the idea of cooling oil. If you had metal in the oil from the previous build you may not want to use the stock oil cooler again.
This leads to me question. If the oil is filtered before it reaches the cooler I don't see an issue reusing the cooler. What direction does it go?
