syclone 0260n4
I dont know why but my oil pressure gauge is not working at all. What would be the best way to go about this issue?
syclone 0260n4 said:I dont know why but my oil pressure gauge is not working at all. What would be the best way to go about this issue?
X2...could be a bad sensor/switchstrada said:check the sensor,mine got nuts i replaced it,not easy to install but is working now.
SY756 said:I know since you've had a Sy before you already know about the gauge flipping over and getting stuck on the bottom pin, right? If that's not it, the sensor could be bad or the gauge itself. The sensor is just behind the distbuter a little to the drivers side.
I just put a aftermarket guage in the pillar pod and didn't worry about it.
Syclone#2960 said:Larry-
This just happened in my Typhoon what caused it? Can it be fixed?
