oil in air filter
gjp
another post whore
I have a KB setup and I have oil in the filter. I know some is normal. I searched and found a few different ways to set up the pvc hoses. Does anyone have pics of their engine showing the right way to set it up to minimize oil. right now I have a breather on the passanger side where the oil filler was and a hose going from driver side rear to air filter (3/4) and a small hose from front passanger side to air filter. Thanks.
pics can be seen here http://www.syty.net/forums/showthread.php?t=30651&highlight=bay+area
THANKS
Bill Z
Re: oil in air filter
gjpright now I have a breather on the passanger side where the oil filler was and a hose going from driver side rear to air filter (3/4) and a small hose from front passanger side to air filter. THANKS[/QUOTE said:
The oil filler should be on your driver's side. Plug up the 3/4 inch hole and use the aftermarket filter that goes where your oil filler tube is. This is used as air inlet into the crank area anyway. Then just connect the PCV on the front of the horizontal hose on the passenger side valve cover to the air breather. This causes a draft across the engine to remove vapors. Air in on driver's side and air out on passenger side.
Hope this helps.
gjp
another post whore
sorry, typo, its on the driver side.
You lost me a bit. So nothing will go to my air filter?? just the passanger side to the driver side air breather??
berzerker
wookie
how bad is your blowby ? maybe something is in very bad shape if your getting quite a bit of oil into your intake system .
93TyGuy
Boost Freak
Right before my engine let go I had lots of oil in my KB cool air kit and through my turbo. It lived as long as it could but it $hit the bed shortly after I realized how much oil was going through.
gjp
another post whore
there is some. most of it is dry like its been there for a while. its what i expect for a 93k mile truck. the intake has been on there for 60k miles and the filter was very dirty. with my hand over the oil filler, I dont feel any air or see any vapors.
berzerker
wookie
well if your not seeing a whole lot of blow by, then the engine is probly allright. maybe u've got a pcv valve stuck ?
The hose from the drivers side valve cover to the air filter is just to give clean air to the PVC system. Any kind of mod here will work if you keep the idea. Don't forget to plug the hole in the air filter if you remove the hose. Functional PVC by itself is harmless performance wise and in fact helps to keep moisture out of the crankcase so try to keep it working in some manner. IMHO
