oil in I/C?
Joey Allen
MUNCHKIN
I took my I/C off last weekend to take my TPI off to clean and put on a new IAC($) valve. It appeared to have a coating at both the inlet and exit . It did not smell but had a slight blackish color to it. Is it possible for oil to get there?
I now know what everyone means about Gremlins. Just started working on small things and bigs problems have followed.
Thanks for any help.
Phoon30
Joey Allen said:
Well, I wouldn't think that would happen cause I just put two new pcv values.
Any suggestions.
Thanks
The oil is probably there from before ya put the new PCV valves in.
Joey Allen
MUNCHKIN
Well when I took my I/C off to do my tune up I didn't notice any evidence of oil then. The frustration factor has gone red line since then, cause I just knew after I got done it would run like nobodies business. But instead I had nothing but problems since. I really appreciate you guys help on the forum.
'92 Ty1635
4C FED
Absolutum Dominium
I'll ask the obvious question; Did you use the correct GM PCV valves?
One other possibilty; Are you using a K&N filter and did you happen to re-oil it when doing your tune-up?
Joey Allen
MUNCHKIN
Yes, I did used the right PCV's and I don't have a K&N filter. Could this be a sign of blow by? I know that the PCV valves play a part in keeping that in the engine.
Thanks
Phoon30
You said you're using the correct valves, but how are you sure? When you got em from the stealership did you ask for PCV valves for a syty or did you give them the part #? I think they should have an "E" stamped on them. Ya might wanna do some searching though cause I'm not 100% sure on the "E" thing. Also before you put the new ones in, did you happen to notice if they rattled when ya shook them? They should. Parts are bad out of the box sometimes.
