Oil in turbo
Kybol
I pulled the piping off the turbo and there is a small amoutn of oil sittin in the bottom of the inlet pipe, and also on the exhaust side housing. Would this be the seal going or what do I do to fix it?
PPI Typhoon
DIY Madman
Re: Oil in turbo
The turbo on the inlet is normal.........as it's part of the PCV system. As far as the exhaust housing........not sure about that one.
bjk_typhoon
1993 Typhoon
Re: Oil in turbo
Could the oil sitting on the inlet side cause smoke during inital start up? Or do I need to change my valve seals?
TurboTony
Re: Oil in turbo
A bit of oil in the turbo inlet is normal when using the stock PCV setup.
It's not the cause of smoke on startup, that is nearly always valve seals.
If you want to get that fixed leave the truck with me for a bit and I can do it for you, won't cost much, mostly labour.
Tony
