oil leak / pressure
Ryda85
Senior Member
hey guys, i have a small oil leak on the sy...its under the center of the motor cab side.
is there a usual leak with these trucks?
also, my oil pressure might be a bit high...its at 60 most of the time...and moves up a tiny bit when i rev it
could these be connected?
sleepy
Re: oil leak / pressure
The oil lines that run up to the cooler have a tendency to leak. I would have a look at these - usually when they start leaking, they just get worse - there's also a gasket in the housing on the engine that will leak if it cracks. I replaced one on a friends truck when it started laeking about a quart every twenty miles. Be careful about little leaks - they get bigger.
- the oil pressure is a little high, but I doubt if it is related to your problem.
Well first thing I thought of was rear main (which leaks regardless of oil pressure) but the adapter for the oil lines is right there also and if it leaked it would be related to oil pressure. 60 is a bit high for idle. Stock gauge? Or a real one? Can you get it up on a rack and look?
Ryda85
Senior Member
yea stock guage....no lift...going top my buddys garage this week to check it out
