Re: Oil Leak
Jim,
If youre using a stock one piece molded rubber oil pan gasket and a stock pan/timing chain cover there shouldnt be any leaks (especially after 6 or 7 pan R&Rs).
Are you sure the leak isnt the crank seal in the timing cover? Its not uncommon for a timing cover seal with some miles on it to wear into the harmonic damper as well as the seal itself get some wear on it and start leaking oil down the front of the motor.
Of all things GM has done wrong the one piece oil pan seals isnt one of them and Ive never seen one leak more than an ever so slight amount even after 100k+ miles as long as the oil pan and timing cover were the correct pieces.
BTW, pulling the pan 6 or 7 times with the motor in the truck HAS to be a test of ones sanity. Im finishing up a JS coil over/motor mounts install and noted that you have to practically take the entire front of the truck apart to get the oil pan off with the motor in the truck. No thanks...
