Oil Preasure Gauge Where??
Hi.. Everybody.
Are in desperat need of some info about where to connect an extern Oil Preasure gauge any info or pictures are more than welcome Thanks..
4C FED
Absolutum Dominium
There is an unused port on the remote oil filter mount. Just tap in there with the appropriate adapters.
dlove
I removed the oil sending unit and the brass fitting that it goes into. I drilled and installed a fitting in the top of the brass adapter. Make sure you use what works with you gauge. I liked this location since it is the same as the factory sending unit (which you keep in place) and requires less tubing in the engine compartment. I don't have pictures but if you email me I can give you a better description.
R
rjcsue
Guest
oil pressure guage has traveled 359 degrees
and rests against post.Problem now is needle is blocked by post.How do i FIX
turboj91
Has anyone figured out why the needle spins around 359 degrees and stays there. I have the problem as well and will tackle the prob. when the truck comes out this year. I read about the upper stop pin but does the needle bounce off the top pin & then settle back to proper operation. When I bought the truck the prior owner advised he spun the needle backwards to the lower pin stop and the gauge worked fine for a while and then went 359 degrees again. He thought the gauge itself was bad and didn't want to incurr the expense of a new cluster. I'm very anal about detail and would like to cure the problem rather than put a band aid on it (no disrespect to anyone who has the top stop pin!) TIA for any thoughts/info. BTW, I will replace the o.p.s.u. just to cross that off the list of possibilities.
<font size=-1>[ This Message was edited by: turboj91 on 2002-03-24 22:39 ]</font>
sy2185
happened to me under warrenty. Dealership sent out guage cluster to be "fixed". No more problems.
Jeremy
V6 Kompressor
Usually, the oil pressure sending unit starts spiking the voltage going to the gauge when it starts to go bad... On some non-rare vehicles (beaters), I have drilled a small hole in the clear plastic gauge cover so I can push the needle back where it belongs, but I wouldn't even think of doing it on a sy/ty, but I did do it on a 97 f-150 work truck last... No loss...Replaced his sending unit also, no more problems...
ghettosled
SYTY SUPERSTORE
use the remote filter mount.. And run braided line to your gauge. Do not use the plastic tubing that comes with the gauge if you are using a mechanical. It will melt and create a mess/safety hazard.
