Oil pressure gauge!
nello
Ok, I've done plenty of searches for oil gauges here and their is some info...however, no detailed info.
I want to get an aftermarked gauge because like half of everybody else on here my stock gauge went lame too.
So, if i get the electical, where and how do i connect that piece and does it come with everything i need to finish the job without ordering a bunch of other junk? If not, then what else will i need. :hissyfit:
http://www.jegs.com/webapp/wcs/stores/servlet/productitem_10001_10002_752319_-1_30724
or Jegs part # 105-2634
Thanks all.
berzerker
wookie
Re: Oil pressure gauge!
on the oil filter housing there is a pipe plug that u can remove to install the sending unit. it does take a special tool to remove because it is metric in size. it looks like a 3/8 '' but is slightly larger.
nello
Thanks, so if I ordered the gauge i posted, would it work with no additional hardware?
The one I'm looking at has 1/8'' sender & 1/4'' fittings. How do I make this work with the filter housing plug?
gjp
another post whore
that same plug can be used to feed fresh oil to the turbo instead of comming off the block. FYI
You may need a bushing (reducer) to get you from 1/4 to the fitting on the filter and you'll need a hot wire to energise the thing (with a good ground at the gauge or ?). If it were me I'd go full sweep mechanical but that's just me. Lots of folks don't like the idea of the potential for oil in the cab. I've never had any trouble doing this with big trucks and little ones.
ghettosled
SYTY SUPERSTORE
you will want a 3/8" npt to 1/8" pipe reducer fitting if tapping into the ol filter housing.
