Oil Pressure Sender location
crazykaese
91ProtoTy/IndyPaceTribute & Sawzall Master
My sender died. I bought a new one - now where is it located on the engine? I posted this question a little while back and somebody replied that it was back behind the distributor. Well - it ain't. I did a cap and rotor this past weekend and was back there and didn't see anything resembling an oil pressure sender. Anybody know where this thing lives?
Bill Z
Crazy,
It is just like Brian said, unless one of the last owners moved it, it is back there by the distributor (just to the drivers side). Just like a Chevy 350. You may have to move some wires and hoses. Trust us, the connector is back there.
My oil pressure gauge showed no oil pressure and I replaced the sensor but it did not fix the problem. I had to check my oil pressure with a mechanical unit. Both the old and new sensors were OK; it was the gauge on my truck that went out. I left the mechanical gauge hooked up.
Good luck with your problem.
Lynn D. Brown
OP Sender
OP Sender
Guys,
Got my engine apart, so I'd like to clarify this also. I remember the remote Oil Filter block bolted to the rear of the drivers side of the block w the Aluminum two line connector bolted to it. These 2 lines then go to the remote Oil Filter. Where is the Oil Pressure sensor relative to this ?
leroy
It's under the distributor, next to the knock sensor. It's common for parts stores to give you the wrong part, so I'm not surprised there's nothing resembling what you bought.
Jim
Lynn D. Brown
OP sender
OP sender
Jim,
So, it screws into the backside of the block, or the side ? I am assuming that the distibutor bolts down to the block, and not the Intake Manifold. Sorry to sound so stupid, but it's the 1st time I've torn the damn thing down.
leroy
It screws into an elbow fitting in the block. The distributor bolt goes into the intake manifold.
Jim
SY756
Re: OP sender
Re: OP sender
Lynn D. Brown said:
Jim,
It's just like Jim said, it's a small diam pipe coming up out of the block right behind the dist, maybe to the pass side just a little, to a hex type fitting that turns it out to 90 deg. That's where the oil pres sensor will be. Should be pretty easy to find since its about the size of a "D" battery on steroids :D
