They probably sent you one for a 2wd engine and it will be too short...actually, just call a gm dealer for a 4wd pickup for a 4.3, be careful at sustained high rpms with a high volume oil pump, you can suck all the oil out of the pan, because the oil doesn't have time to drain back...I wouldn't put a high volume pump on unless I could get an oil pan with at least an extra quart in it...
