Oil pump questions, Pics inside
Z SKI
Hey guys, I noticed that i have a M55 HV pump on my new motor. I was wondering if this is the thinner casting one that has been breaking? Let me know. Thanks, Paul Z.
NecroWolf
lost marbles member
Re: Oil pump questions, Pics inside
looks just like the one i have and was told it was the "weak" one.
4C FED
Absolutum Dominium
I would not buy the M55HV.
The correct one is M Select Series 10550 for a HV pump.
EDIT: Now that I look at that pump longer it looks ok.
It's nice & thick around the mounting bolt hole.
Stick with that pump. :tup:
4C FED
Absolutum Dominium
See how the casting molds around the bolt hole in the pump up front. If yours looks like that, use it for a paperweight.
NecroWolf
lost marbles member
get the oil pump pick up support and you should be good
Z SKI
Thanks all, My pump doesn't seem to get get thinner after the bolt hole. Ill run it:tup:
Syclone #1721
I LOVE 4UM SUPERSTARS
It looks like the lightweight casting. You shouldnt have a problem if you dont hammer it too much installing the screen. I built race engines for 10 years and I rememeber when Melling went with this other casting, Heres the thing....Ive seen this time and time again...when installing the screen, you have to be careful about driving it in. This is where the breaking occurs....it usually cracks but you cant tell...then once you start the eninge and it runs, the harmonics finally break it loose. We actually did in house testing where we magnafluxed the pump before and after installation and found cracks after the screen was installed. I have used plenty of these lightweight castings with not one failure. Just installed one yesteday on my Formula engine. Use the correct install tool and dont drive it too hard and you will be golden......on another note, I have to ask if you are using the stock pan. If you are, I would strongly reccomend checking you screen to pan clearance. When you use a high volume pump on a 4x4 s series pan, the screen usually presses tight up against the bottom of the pan impeding flow becasue the high volume pump has a taller body. Something to look for as I have seen it happen many times. Good luck with the build. :tup:
