oil pump
sean
got all of my parts for the lower end. i have h-beam rods, (30 over) srp piston, 4 bolt, arp bolt for the 4 bolt, nitriod crank, 412 cam, doubble roller chain, when i'm done with the lower end this is what i plan to due with the upper end going to fully port and polish heads (vortec) 1.6 rockers, port and polish upper and lower intake manifold, going maybe with the gt35r turbo my ? is what is the best oil pump to buy for the set-up??????????
scotts4
ADDICTED
Re: oil pump
Use the melling m55a with the stock pickup if you are using the stock pan and have the pick up welded on
sean
Re: oil pump
jwaller do you know the part # for every thing i need for the pump? such as the shaft
