Neelsonwheels
Hey,
It seems as though my new motor build is using oil.
I check the level and make sure it is in the proper opperating range and then drive it.
After only 100 mile or so the oil level after cooling down is low.
I also notice the oil pressure drops when the truck get hot.Not sure if this is common.
I don't see smoke when I start it and no leaks under it.I am hoping it is not a ring issue.
Any help would be great. Thanks
