Lynn D. Brown
Hey Guys,
Just a Heads up on using the stock Oilpan on the Bowtie block w GM steel 4-Bolt Main Caps. The Caps come out essentially all the way to the sides of the block, and the 2 middle caps run into the sides of the stock pan where it curves in. Also the side of the #2 Cap kinda interferes w the turbo Oil return.
So, U either have to cut up the pan, or have the the edges of these 2 Caps trimmed off at the machine shop. I wish I had known this while the the block was at the shop. Then beyond getting this to fit, it appears that many of the Forged Rods available, like the Eagles, also interfere w the Pan and U have to do some more banging there also.
Another option is Mike Lee's aftermarket pan for our cars, which is a beautiful piece, albeit a bit pricey. I'm checking w GM now on some pans that they have available for the "T" series 4WD trucks, which I think are the 3/4 Ton versions of our truck
