ok i got a code 43 poping up?
could that be the reason the car runs all goofy?? i mean i just changed everything with good plugs cables rotor cap ignition module? does code 43 cause the truck to have boost problems??
Turboz
NASTE
Re: ok i got a code 43 poping up?
code 43 ESC failure. (ESC) The ESC retard signal has been on for too long or the system has failed a functional check. I am going through this code problem right now. If you search you will find some posts on this. But basically most of the time it relates to the knock sensor. When this happened to me though my truck didn't run crappy it actually ran better because there was no timing being pulled out when there was knock and as you know that is bad. Hope this helps, and I am sure someone more knowing will chime in to help as I am no expert, this is just what I have read.
jay
jay
Actually, in my Chiltons, which covers Sy's too, it says that causes retard in the EST signal when it's too long ot fails the fuctional check.
