TYTILIDIE
METH HEAD
So here is the scoop on my engine. The block I used is in fine shape, needs no machining again, just cleaned up. The Lunati rods I was running are in perfect shape, two pistons are trashed, new ones are $108 each. Since the crank was an offset grind, this puts me in a tough situation on "what to do". If I go back to a stock type crank, I will need new rods and pistons. I got a set of Eagles that the shop believes to be junk. Still waiting for that news. So my options look like this. Shop has an offset ground crank only it is not ground, it was actually a forged crank built for the purpose of being a stroker. If I run this crank, they want $1000 for it. I would be able to buy two new pistons and re-use my rods. My other option is that I got a stock crank the shop says would make a great .10/.10. If I go this route, it is just a stock crank, I would need new rods and pistons. I could go with the RPM crank but I hear nitriding is only a surface treatment (shop telling me this) and really isn't worth the money over the forged unit. If I were to break down and go with RPMS unit, I still need to buy new rods and pistons. Does anyone think a forged crank like this would stand up to what I am doing? It does have the small journals but I figure if its forged?
Next is block decisions. My block is fine. I have however, acquired a 4bolt block with caps for very cheap. (Thanks Aaron:tup
. Shop wants to see it go to .040 over which is fine with me because thats what my other block was. Problem here is, all machining needs to be done except align bore.
Sothese are my options, what would you guys do?
