OK, so what is wrong with this
jhj
GReddy Profec B Spec-II Turbo Boost Controller Spec 2 going to try for 18psi,
Pit Bull street chip, Stock injectors or 50lbs injectors, Snow- 50x50 mix.
Will I blow it or FIU. I have the 50s and as in my signature have installed a Wilbro 255 pump. I am not much on computer tuning, so you guys and gals that are vg on this stuff could you give your 2cents on this. I will be eternally greatful if you keep me from detenating my 4.3. Thanks, Jimmy Young a old time carberator person.
sharkbait
Re: OK, so what is wrong with this
:2cents: but i think everyone is gonna say get your truck running right with code59 before you start spraying meth etc.
but this is coming from a carb guy that doesn't have syty motor in his S10;)
turrrbo6
get a 3bar map and a 3bar chip b4 you try to make more boost than you can fuel!
turbodig
There never was an ATR chip for 50# injectors.
Your injectors and your chip *must* match. You can't mix and match chips with different injectors.
Also, the only chip that works well reliably, is the one that is custom-tuned for your truck. This involves either taking your truck to someone who can do it, or working with someone via e-mail, which would mean that you'll need to have the necessary scan tool software, a wide-band, and an ostrich or something similar.
You can't make up for a bad/mismatched tune with alcohol. Sure, it'll help, but it won't forgive all the sins.
People don't seem to want to believe this. They keep trying shelf chips from the vendors that are still selling them (fewer all the time), only to find that it doesn't work with their combo. Or, they try to fix mechanical problems with a new chip. Or, they take a truck that's knocking/breaking up, and try to fix it with an alky kit.
It doesn't work. It never did. Want proof? Look how many motors are in pieces, are hurt, or are in the process of being rebuilt. Then, look at the bone stock, never-touched-a-thing guys that have 100k+ on the original motor. Daily drivers, at that.
You can do this one of 3 ways-
Spend your time throwing "bolt-on" parts at it, and end up with a dead motor eventually.
Work out a good combo, learn to tune your own stuff, and have a decent amount of success. This takes a lot of time.
Take it to somebody, pay them to set it up right. This takes a lot of time, and a good amount of money.
95xtreme
I would like to just high light the end of digs statement here. I do not know where to start with tuning these trucks or even my xtreme. Luckily I live near dig. So I spend the money and have him do it if he can and give him time to do it.
But from my tuning experience with with hp tuners you never get anywhere with out the tune. Sure you can up injector size change out cams etc. and fell gains in power (most of the time) but you do not unleash the true potential of the upgrades with out the proper tune .
just my 2 cents
jhj
Ok dig I get the point. Do you know of any one in MD. who is a tuner of our trucks?
cloneman315
put the stock chip and injectors back in and get it all dialed in first,Im not a big fan of alky kits..
jhj
As it stands now, I have the PitBull and the Snow 50-50 installed, the truck runs great. I have a 3bar chip and 3bar sensor that I can install along with the Greedy Profec. I know I should get a Datamaster read on it. If I had someone near by I would be glad pay them to read my truck so that I could send it to someone who could ''burn'' my chip. Does this make sence?
turbodig
It's kinda thin for SyTy tuners on the east coast. I'm not aware of anybody further east than Indiana.
You guys should goad Harry A. into doing stock ECM tunes. It'd be a good thing to have somebody in the know out there.
turbodig
The thing of it is, any tune you get done will require *lots* of files (between 10 and 50) to get sent, and a lot of bins getting sent to you. You'll want to have the equipment yourself.
There's nothing wrong with doing an e-mail tune, it just takes a bit more time since the tuner can't see/hear/feel/smell the thing while tuning. He has to rely on your description. The person getting the tune also has to be willing/able to fix what needs to be fixed, and stick with the process.
You'll need:
A wideband o2 setup - $200
A DataMaster Cable ($40-$90) (Assuming you have the laptop)
A Chip adapter + PROM ($55)
A basic burner ($40-$85)
Once you have the above, people can help you from pretty much anywhere.
