Older Bowtie Block Questions
MRKING
New Parts for Old Trucks
Has anyone ever used any torrington bearings in a syty application ? The block I got from a friend of mine was setup to use torrington bearings at the camshaft and I cant find info on them anywhere . I have some used ones to go by and they have a "J-3016" on them . I traded parts for parts and got the block at a great deal , but see there will be work involved in getting this block ready to run .He found it wasnt what he expected when he bought it and wanted nothing to do with it anymore, so I made a fair offer and he took it. Heres a pic of the bearing . Can one of you guys help me out . I even tried a google search but cant find where to buy more .
myclone
Re: Older Bowtie Block Questions
It seems Ive read/heard somewhere that when the nascar guys convert the cam bushings to needle bearings that the ID is different and it requires custom journal'ed cam. Basically a stock cam will no longer work.
Dont quote me on the above though as its just what Ive heard/read here in nascar country and may or may not be true. Also, since the lifter oil galleys are fed from the cam bearing journal you may need to address the top end oiling if youre using hydraulic lifters. Im betting that with the needle bearings in the cam journals the oiling is restricted since solid lifters were used in the racing set ups.
From looking at the oiling system diagram the galley plug that is in the area of the filter will need to be removed. Acording to the diagram that passage way is the supply from the oil pump in a wet sump system. I will look at one of my stock blocks to try and verify that shortly.
HTH
MRKING
The top end of this block would use Jesel solid rollers . Some came with the block when my friend bought it but they were not a complete set and I never got those with the deal. I found a used set on ebay for $200 but dont know if "one race old parts" will work well . The ID of the torrington is 1.87 and I believe that is the stock size , so I was gonna check a stock cam and see how it fits on the used bearings I have . Thanks for the reply myclone . I deffinatley have questions when it comes to max effort race engines .
jwaller
Evil Genius/SyTy Guru
you will need a custom cam blank that uses roller bearings, the bearing surface haas to be super hard and those blanks for a 4.3 are very pricey. and not worth the 1/4 more hp you gain from it.
Syclone#892
Try and get a hold of member 4c Fed on the board. He had a McCoy super motor that spun a cam bearing and from what I remember he converted the block to that style of bearing. Good Luck with it.
