Oliver rods-no machining required
cameronsclone
I have a set of 6 Oliver connecting rods out of my truck. Just got them back from the machine shop, checked out fine. I'm sure everyone knows about how stout these rods are, I don't believe any one has ever broken or bent one in a syty. These are the same rods McCoy used in their 291ci 1000hp engine (http://www.syty.net/forums/showthread.php?t=48412&highlight=oliver+turbo). They're in great shape, require no machining to fit, won't hit the bottom of the oil pan. Part #C5700 EXLT6. Like I said I pulled them out of my stock (or so I thought) engine. I have a set of TRW pistons for a .030 over block I will throw in if wanted, but I'm not sure if they can be reused. The only blemishes on them are the cylinder # etched into each rod on the big end, and the #5 and #1 have a few tiny dings on the sides; nothing major, I tried to sow it in all the pics. I ran them for ~5k miles, used only mobile 1 synthetic, never made enough boost to worry about hurting them. I'm looking to get $700+shipping for these or I'll take partial trade for a progressive alcohol injection kit+cash. Originally retailed for ~$1000 new, good luck finding some now besides these and the few others unknowingly lurking around. Thanks.
Here is a link to all the pics, should be first page or two.
http://s36.photobucket.com/albums/e26/300zxman/
TxSy1430
Re: Oliver rods-no machining required
hey cameron..why aren't you reusing these in your rebuild?...or do you need to sell them to finance some of the rebuild?
cameronsclone
Overkill and in need of money mostly. and I had already had another engine ready to go and paid for when I pulled these out.
Syclone#2960
What ever it takes!!
wow those look great. good price too. Someone should jump on these.:tup:
sy2206
If someone needs the rest of the motor to go with these, I have a very nice block/crank for sale. It has no heads or connecting rods. The block is .030 over, converted to 4-bolt billet mains with a billet front cap and has an un-cut, nitrided crank that was new when the engine was built 1000 miles ago. It’s got a B&M flexplate, Fluidamper damper, CC 422 cam, CC timing set, CC lifters, TRW forged pistons with C&A Zero Gap rings on them and Edelbrock water pump. The pistons are numbered to the cylinders they came from, so with these rods and some cleaning, the short block would be ready to go.
Just throwing some options out there for you guys.....
Windedv6
Ty n 10s
:bump:
Hoovers also used these rods in their truck.
I am interested, but have a couple of questions. What caused the nicks? Did something come apart? 1,000 on the motor? What was the problem?
As far as the rods. Can you take a calibers and measure the exact width of each rod? I have seen used rods machined down to achieve the proper rod side clearance, then not be correct when trying to use them on another crank with slightly wider crank journals. It should not be a problem on yours as they were on a "stock" crank. It has been a problem for me on a custom billet crank setup.
Before I would decide to purchase them I would want to know.
John
cameronsclone
I'm not exactly sure on the mileage. I've put ~5k on since i've owned it,and the previous owner was the one to put in the olivers. reason I tore into the engine was a bad rod bearing. started losing oil pressure and heard a ticking. On the measuring thing, I'll have to look into it. What does a caliber measure, the big end where it mates to the crank?
NecroWolf
lost marbles member
bump for our resident syclone minor. did that cable work for you?
