? on 60lb injectors
s10pro
going code $59 or have nolan. do i want low or high inpedence also long or short style thanks
turbodig
Re: ? on 60lb injectors
The ones I have on my truck aren't flow matched and they work just fine.
The Siemens/Mototron injectors are very consistent right from the factory.
Not really... we have many ranging within a 10% window and some beyond that.
We offer them in non-FM and FM. The FM versions cost more b/c of the labor and inventory required to provide them.
I would say if someone really wanted to get fancy they would have the injectors flowed and marked, then do plug readings or even better wb o2 in each cylinder and move injectors around so the cylinders were closer to even. Lots of work, probably not a lot of gain but hey.
On a note I find somewhat funny is we put flow matched injectors on a motor that is far from flow matched.
So you would have no problem placing a random injector that is 5-6% down in a lean cylinder?
How do you know you would get a set that would allow you to balance out the cylinders after the fact?
What about the effects on idle quality, engine response and max HP w/o detonation?
Then there are those injectors outside of spec. or with odd spray patterns.
Why would someone want to introduce a wild card into their high-performance mix for the cost of a tank of gas?
These are all rhetorical questions.
This topic has been debated for years again and again on these forums. The merits of FM injectors are proven at the track and on the dyno. All reputable tuners use and recommend FM injectors. Only retailers who put price ahead of quality and performance generally dismiss the merits of FM injectors.
wildphil
I Love My Ty's
Not long ago I saw on the Turbo Buick site were your company offered a discount. Could you also run the offer to our members?
I won't argue there is an advantage. I will argue 90% of the owners on this board wouldn't notice that difference.
