On/Off Whining noise while idling????
Josh in RI
Hey guys,
As usual, I've got something else with my truck. I'm getting this whining noise while the truck is idling. It's coming from the back of the engine, what I thought was the cap + rotor, but after replacing that today, it's still whining. The only code the truck's throwing is a 13- open O2 sensor circuit. This is probably due to the air/fuel mix guage I put in. But the whine sonds like it's either the distributor, or the damn EGR valve on the plenum. Any insight on this would greatly help, so I don't start breaking my truck. If it is the EGR valve, where can I get a new one for this truck, besides the dealer :roll: ? The noise is driving me up a wall, and I must put an end to it. The truck don't have any loss of power, or losng power, just this fairly-loud whine PLEASE HELP!!!!! Thanks again, and as always, you guys rock :rock: ! Thanks, Josh
I bad egr will some times tick (clatter) typically its not whining sound. It could be your distributor gear, they done evetually wear out and with over 200K it could be on it lasy legs.
odium
1BADGMC
Also try the tire tube truck found at the sytyarchives.com website to test for vacuum leaks. If they break just the right way, they whistle. Quick and simple check, might as well!
mtb9192
r.e.whinning noise
r.e.whinning noise
Josh:
Just my 2 cents, but I have a whinning noise that I thought was coming from the back somewhere and I have been told I need a new turbo. But if you aren't loosing boost or your regular power gains when shoving it to the floor. Then maybe I'm wasting your reading time here?
Good Luck.
I'm needing a turbo after 58k miles
gmcturbo
i would say you might have a leaking vaccume line at the back of the intake. the engine pulls the most vaccume at idle and that would explain when you hear it. i would just be safe and replace them all. might want to put it up on a rack and make sure its not the transmission/torque converter or starter hanging up..
spooldup
Super Member
Re: On/Off Whining noise while idling????
this is the same noise as my ty is making from the same area. did you find out what it was?
Zewerr
ToeJam is a Poindexter
Reading just the title of the post, the first thing that came to my mind was the A/C compressor. But then after reading the rest of your post, probably not.
spooldup
Super Member
ok i spayed wd40 on the top of the distributor and it stopped. I guess i should install the msd i've had laying around.........lazy...
