One last DIY WB question..
myclone
What kinda current draw is on the heater ckt? I dont have the O2 in hand to measure the heater current draw. Im making up cables and dont wanna go too small but I want the heater conductors the right size and still have the cable look neat.
TIA
TurboTony
Hey Dave,
I used 16 gauge on the first one and 18 gauge on the portable. Fused them with a 5 amp, no problems with either so far.
The somewhat weird thing is the second heats up quicker than the first.
Tony
myclone
Cool... looks like my wiring wont require engineering to work and I can use the cable I have on hand.
Thanks bud.
B
Blake
Guest
Might sound silly but I had the wiring harnesses left over out of my old Gateway when I upgraded the power supply in it. I was worried about the size of the wire so I used the biggest stuff that would fit. Funny thing was that the colors of the wire harness in my Gateway matched the wire colors of the sensor :-?
When I finnally got the sensor, discovered that I used wire almost twice the size of the wires of the sensor(damn they are a small gauge).
Sy#26 recommended a 5 amp auto blade type fuse to protect it also.
Turn it on with ignition through a relay. That's what I plan to do if I ever get to work on my truck again :roll:
Blake
